Autor Tópico: Ducati Panigale V4 em 2018...  (Lida 28722 vezes)
Março 22, 2018, 21:37:06, 21:37
catb
  • 105
  • Marca Motociclo: Piaggio
Esta menina com o Dovi vai dar grandes bigodes este ano à concorrência .
« Última modificação: Março 22, 2018, 21:41:41, 21:41 por catb »
Março 23, 2018, 02:53:55, 02:53
Isto é uma Panigale V4... não Desmosedici GP18.  ;)
Março 23, 2018, 07:46:07, 07:46
  • 18524
Segundo li, a marca foi muito rápida a actuar.
O dono da moto pertence ao forumducati.com e reportou o que se terá passado e que já foi divulgado em vários websites, mas não sabendo ainda causas...nem ele nem a marca (que no entanto está a investigar a situação e não deixará o seu cliente sem moto).  :nice:
"(....)Most superbike owners no matter the brand or manufacturer will know about the heat the engines can generate but it’s very unlikely that the heat is strong enough to turn the bike into a huge ball of flame. Unfortunately for Nitrouz (nota: nome do membro no fórum), riding on busy streets at moderate speeds somehow led to the fire in which Ducati was quick to respond and provide assurance for the new Ducati owner.
The rider was riding normally on 15 March 2018 when he smelled something burning and was horrified when he looked down and saw flames spitting out (and not the good one that usually comes out from the exhaust pipes).  The rider quickly pulled over before the bike was completely drowned in the fire. Luckily, no one was harmed during the incident.
Ducati North America responded quickly to the owner where they have promised a brand new bike (plus sympathies) to the owner. Nitrouz was thankful for how fast Ducati reconciled the situation in the best possible way. Kudos to Ducati North America for such a fine job."(....)
http://www.bikesrepublic.com/featured/2018-ducati-panigale-v4-catches-fire-canada/
Maio 09, 2018, 13:27:13, 13:27
  • 18524
Nos States estão a fazer um recall por causa da possibilidade de fuga de combustível...
http://www.visordown.com/motorcycle-news-general-news/ducati-issues-usa-recall-panigale-v4
Não sei se chegará ou não à Europa, mas será o mais provável.
Maio 09, 2018, 14:11:08, 14:11
Cá em Portugal são os proprietários que fazem um recall por causa do preço dos combustíveis :)
Maio 09, 2018, 19:53:07, 19:53
  • 18524
É possível. Somos todos diferentes e olhamos para os gastos cada um à sua maneira, mas ainda assim creio que o consumo/custo do combustível que resulta da condução de uma Panigale, deve ser para o seu feliz proprietário um dado bastante relativizado. :nice:
Setembro 17, 2018, 11:21:58, 11:21
Setembro 17, 2018, 14:44:10, 14:44
Africandruglord
  • 466
  • Modelo Motociclo: MT 07
  • Localidade: Algures
O campisi tem feito um grande trabalho nessa mota. Só de pensar que um felizardo a vai levar pa casa de borla 😒
Estamos a falar de qualquer coisa como 50k de peças em cima,  está ao nível da superleggera.
Só de olhar pas galinhas daquele pneu começo a chorar.
Setembro 20, 2018, 00:07:08, 00:07
  • 18524
Bem....acontece.
Mas é algo que vai sair bem caro.
Mais uma de entre outras tantas quedas no "Tail of the Dragon".  :-X
Está foi postada há dias....
Setembro 20, 2018, 00:12:40, 00:12
40kmh contra um monte de terra fofinha com mato...
Podia ser bem pior!
Setembro 20, 2018, 00:41:17, 00:41
  • 18524
Viste como ficou do lado esquerdo?  :)
A queda não foi nada meiga para a moto. O mesmo não digo para o piloto, mas a dada altura percebe-se que mais de um terço do guiador ficou pendurado pela cablagem. O pedal selector da caixa também dá ideia que foi com as "urtigas" e aquelas carenagens devem ser um dinheirão. O banco aparentemente desapareceu... :)
Mesmo a baixa velocidade, o estrago não foi nada meigo.
Ah...e aquele quadrante imagino que estivesse a marcar em milhas, não em kmh. ;)
Edit: o banco não desapareceu. O que se vê de cor amarela não é espuma tipo poliuretano. É mesmo uma toalha amarela.  :o
« Última modificação: Setembro 20, 2018, 01:13:53, 01:13 por Sapiens21 »
Setembro 20, 2018, 01:40:09, 01:40
O arranjo será caro porque são equipamentos caros.
Mas a queda pareceu-me bastante fofinha.
Aparentemente nem perdeu peças...  :D
Setembro 20, 2018, 01:47:04, 01:47
É uma delapidação acelerada de património.
Dezembro 23, 2018, 19:46:59, 19:46
  • 18524
Depois de um recall por fuga de combustível e depois mais tarde outro relacionado com a travagem (ainda que por defeito de material do seu fornecedor Brembo), agora surge outro recall para o modelo e que abrangerá 7.132 unidades vendidas em todo o Mundo.
O motivo pode ser lido na imagem abaixo.
Janeiro 19, 2019, 11:11:02, 11:11
  • 18524
RECALL: Ducati >
- Panigale V4
- Panigale V4 S
- Panigale V4 Speciale
"A crack may occur at the level of the outlet pipe of the oil cooler. As a consequence, oil may leak leading to an accident."
Janeiro 19, 2019, 14:09:31, 14:09
Responder #65
  • 18524
RECALL: Ducati >
- Panigale V4
- Panigale V4 S
"There is the possibility for engine oil to leak from one of the hydraulic tensioners for the front and rear bank timing chains. The oil may leak onto the engine sump and onto the tyre"
Janeiro 21, 2019, 19:43:07, 19:43
Responder #66
  • 18524
Uma Ducati Panigale V4 Speciale (na Isle of Man).
Coloquem os headphones... :confetti:
Janeiro 24, 2019, 13:35:29, 13:35
Responder #67
  • 18524
Para o caso, não liguem à imagem...
Vejam o título...  :o
"(....)The Panigale family takes up a fair chunk of the accountant’s spreadsheet, with 9,700 bikes (70% increase on 2017), being either the V-Twin of V4 machines. This means Ducati sit firmly at the top of the superbike segment with a market share of over 26%. In 2018 one superbike out of every four sold worldwide was a Ducati Panigale.
The newly introduced, and much-lauded V4 chipped in a massive 6,100 units sold globally in just its first year, more than paying back the hard work of the design and development teams who helped to created it.(....)"
   :nice: :nice:
Link...
Fevereiro 04, 2019, 19:49:52, 19:49
Responder #68
  • 18524
A fortíssima travagem, com os Brembo a fazerem o melhor que sabem, não foi o bastante...  :(
Foi "cumprimentar" de frente os rails do lado contrário da estrada...
Fevereiro 04, 2019, 20:01:01, 20:01
Responder #69
Tudo bem quando acaba bem, o realizador ainda aproveitou para realçar as curvas...
Fevereiro 04, 2019, 21:12:08, 21:12
Responder #70
O gajo é gordo, ou o airbag disparou???  :pensador:
Fevereiro 04, 2019, 23:14:04, 23:14
Responder #71
  • 18524
Falta de conhecimento do "traçado" improvisado, talvez...
O tipo também vinha bem picado naquela pequena recta antes da curva.
Não se magoou e também não foi uma moto com a sucata como destino.
Não deixa de ter ali um arranjo que qualquer concessionário da marca fará por "engordar nos zeros" colocados à direita do primeiro número.  :)
Fevereiro 04, 2019, 23:19:10, 23:19
Responder #72
Já repararam que não primeiro video que aqui se coloca em que ocorre um despiste perto do local onde estão curiosos a assistir?
Fevereiro 04, 2019, 23:34:44, 23:34
Responder #73
  • 18524
Será que...(mera hipótese)...são os olhares de toda essa plateia, que depois criam em muitos condutores uma confiança excessiva que os leva a fazer "borrada"?
Fevereiro 05, 2019, 00:19:39, 00:19
Responder #74
...que depois criam em muitos condutores uma confiança excessiva que ...
Aquele tipo de "confiança excessiva" que faz uma pessoa gaguejar quando tem que falar em público?   :)
Fevereiro 05, 2019, 11:35:57, 11:35
Responder #75
LOL
De meter os "pés pela cabeça" ou "enfaixar-se nos rails enquanto olha para a câmara"  :stuck_out_tongue_winking_eye:
Fevereiro 05, 2019, 12:50:18, 12:50
Responder #76
  • 18524
O "The Missenden Flyer" responde à questão sobre se será possível conviver com esta moto numa base regular.
E atentem que ele teve uma unidade com ele durante algumas semanas para poder responder a isto de forma mais "qualificada".  :)
O vídeo é grandote. Já vi uma boa parte. O resto fica para mais logo...
Fevereiro 06, 2019, 08:04:25, 08:04
Responder #77
“Best sport bike on the market, period!
Expensive to buy and expensive to own (maintenance, tax and service) but the top of the class, and I’ve driven most of the competition...”
Fevereiro 06, 2019, 09:56:16, 09:56
Responder #78
Acho que ele é ou era proprietário de uma Ducati.
Ultimamente têm-lhe sido emprestadas máquinas para experimentar durante alguns dias ao contrário do que acontecia "normalmente" com o empréstimo por umas horas.
Fevereiro 06, 2019, 10:11:58, 10:11
Responder #79
Ele é proprietário de uma Ducati Panigale 959 (baby brother da V4)...
Fevereiro 06, 2019, 11:17:54, 11:17
Responder #80
Não me chateava mesmo nada.  :yeah:
Abraço.
Fevereiro 07, 2019, 00:28:41, 00:28
Responder #81
baby brother da 1199.
Da V4 é uma espécie de half brother pois é fruto de um outro relacionamento mais recente.
Fevereiro 07, 2019, 07:08:03, 07:08
Responder #82
Sim, para sermos mais correctos, sim, da 1199. Estava a referir comercialmente, pois as v-twin já não se comercializam...
Fevereiro 07, 2019, 10:13:00, 10:13
Responder #83
Deixem lá: com uma qualquer das referidas já me contentava.  :blush:
Fevereiro 09, 2019, 15:35:17, 15:35
Responder #84
  • 18524
Uns amigalhaços numa estrada praticamente deserta...e dá nisto. Um vídeo acabado de postar no YouTube vindo (parece-me) da terra do Uncle Sam. :)
Uma S1000RR também se junta à festa das Ducati, passado o primeiro despique.
Março 07, 2019, 19:10:46, 19:10
Responder #85
  • 18524
A Ducati está a trabalhar numa V4 naked.
Será uma Hyper-Fighter que foi já indirectamente confirmada pelo boss da marca, Claudio Domenicali.
Março 08, 2019, 09:43:08, 09:43
Responder #86
Huummmm
 :blush:
As naked estão de volta.
Essa deve se rum canhão que um gajo tem que se atar à mota só para acelerar a fundo.  :yeah:
Julho 20, 2019, 10:16:09, 10:16
Responder #87
  • 18524
Um vídeo colocado online há apenas 2 semanas, contendo diversas passagens que dão destaque essencialmente à sonoridade produzida pela Panigale V4 e à sua capacidade de aceleração..  :nice:
Uma moto com uma aceleração respeitável e que quando levada ao dyno (com um Akrapovic completo), se atira para números que não ficam a dever nada à concorrência.  :zangadoregras:
