Autor Tópico: A recente chegada ao mercado do Shoei Neotec II  (Lida 5487 vezes)
Fevereiro 10, 2018, 10:50:44, 10:50
Lida 5487 vezes
  • 18434
DESIGN CONCEPT
Seamless “flip-up” versatility of a true two-in-one helmet
Wind tunnel-tested shell aerodynamics and noise-reduction technology
Designed for seamless integration with SENA SRL communication system
Convenient flip-down internal sun shield
Next-level modular helmet design for today's hybrid motorcyclists
INTERCOM READY DESIGN
Designed for seamless integration with the SENA SRL Communication System
SRL is specially developed for the Neotec II, and is sold exclusively by SENA
For more information on the SENA SRL Communication System, please contact your local dealer or visit sena.com
FLIP-UP CHIN BAR & FACE SHIELD
Safety and protection of a full-face helmet
While at rest, converts instantly into an open-face configuration
Large lock release button facilitates easy handling with gloves
Lightweight chin bar/face shield rotate with smooth precision on a variable eccentric-axis, yielding the seamless versatility of a true two-in-one design
All-new dual locking system for improved holding power when in the fully-opened position
360° PIVOT
LOCKING SYSTEM
Road tested and made of high-quality stainless steel components
Safe and secure closure when chin bar is in the down, locked position
AERODYNAMICS
Wind tunnel-tested aerodynamics optimized for varying riding positions
Shell-integrated spoiler has been reshaped/repositioned to further reduce lift and drag
Top air outlet serves as a spoiler while in an upright riding position
Newly designed 'Aero Deflector' for improved chin bar aerodynamics
NOISE-REDUCTION
All-new 'Noise Isolator' cheek pads deflect wind and reduce unwanted noise
New airtight window bead and the chin bar’s 'Vortex Generator' lip reduce noise and manage airflow around the helmet
Enhanced shell shape improves noise control and aerodynamics
Refined in SHOEI’s in-house wind tunnel
Reduction of unwanted wind and road noise
CNS-3 SHIELD
All-new design provides improved air/water sealing and noise reduction
Protects from 99% of the sun's damaging UV rays
3D injection-molding ensures distortion-free view throughout the entire field of vision
New airtight window beading drains/prevents water from entering helmet
Comes equipped with a Pinlock® EVO fog-resistant system
CNS-3 BASE PLATE SYSTEM
Facilitates smooth and easy shield changes
SHOEI’s patented spring-loaded technology ensures a wind and waterproof seal
INTERNAL SUN SHIELD
Built-in QSV-1 sun shield gives riders instant relief from sun glare in one quick motion
Large, easily located switch activates the 3D injection-molded inner shield
Distortion-free view blocks 99% of the sun's damaging UV rays
Forehead area of outer shell is raised slightly to accommodate the internal sun shield, allowing for the integrity of the helmet's inner EPS liner to remain intact
Exceeds ANSI Z80.3-2010 Standard for non-prescription eyewear
VENTILATION PERFORMANCE
Large upper and lower vent shutters for ease of use with riding gloves
Expanded 3-position upper air intake for increased ventilation performance
All-new exhaust outlets flank upper air intake for improved hot-air clearing
Wind tunnel-optimized for dramatically-improved cool-air intake and hot-air expulsion
MULTI-PLY MATRIX AIM SHELL
Proprietary technology integrates a five-ply matrix
Hand-laid interwoven layers of fiberglass with organic fibers and resin
Shell-integrated spoiler with consistent shell thickness guarantees proper strength and weight
MULTI-PIECE EPS LINER
Provides enhanced impact absorption by utilizing varying densities of foam
Allows cooling air to travel unrestricted through tunnels created in the EPS
Precise placement of multi-density EPS material yields a more compact, lightweight design
MICRO RATCHET CHINSTRAP
Patent-pending 100% stainless steel interlocking mechanism
Quick and smooth closure and opening
Comfortable and easily-adjustable
INTERIOR COMFORT SYSTEM
Fully removable, washable, replaceable, and adjustable
Multi-layer cheek pads for comfort and helmet stabilization
Three-dimensionally shaped to match the contours of a rider's head
New 'Noise Isolator' cheek pads deflect wind and reduce unwanted noise
Página oficial: https://www.shoei-helmets.com/neotec-ii-features-summary e a inglesa  http://www.shoei-europe.com/uk/news/the-neotec2
Fevereiro 10, 2018, 13:01:18, 13:01
Os melhores 3 capacetes modulares do mercado, BMW SYSTEM 7, SCHUBERTH C4 e este shoei-neotec-ii
Já gora os preços,
https://www.motorraiz.com/shoei-neotec-ii
« Última modificação: Fevereiro 10, 2018, 13:04:38, 13:04 por Clemente Vicente »
Fevereiro 10, 2018, 13:41:35, 13:41
  • 580
Espectáculo! Parece-me um pouco mais compacto que o anterior.
Alguém quer um Neotec série I?!
Fevereiro 10, 2018, 13:42:48, 13:42
rodd
  • 156
  • Localidade: Torres Vedras
Já gora os preços,
Os preços não são nada convidativos, pelo menos para a maioria dos bolsos Portugueses... Se quisermos muito o capacete é necessário ter alguma paciência e aguardar por uma promoção e, assim, adquiri-lo a um preço mais em conta...
Boas curvas
Fevereiro 10, 2018, 13:50:41, 13:50
Fevereiro 10, 2018, 14:29:18, 14:29
Comprei o Neotec acerca de 2 meses. Acho que fiz boa compra, pois comprei com um promocional que me ficou quase a metade do preço!!
Fevereiro 10, 2018, 15:46:29, 15:46
  • 1531
Pois agora deve ser é bom para apanhar boas promoções do Neotec I
Mas o II tem muito bon aspeto. O problema é mesmo o preço...
Um abraço
Fevereiro 10, 2018, 16:06:27, 16:06
  • 580
Na altura também aproveitei uma promo, caso contrário talvez não o tivesse comprado.
Mas que este está com alto look, lá isso está ;)
Fevereiro 10, 2018, 16:32:28, 16:32
O neotec I na motorraiz está com 25% desconto. Mesmo assim ainda o comprei por menos 100€ que este promocional  :cool:
Março 19, 2018, 03:02:02, 03:02
O Clemente com tantos capacetes caríssimos, se os vendesse no ebay dava para comprar uma Super-duke GT.
Ficava só com um Schuberth.
Março 19, 2018, 17:42:36, 17:42
Olá pedro
por enquanto não me debrucei na pesquisa de informação desse Super Duke Gt .... não conheço
acabei á duas semanas de vender um dos Scuberth C3 pro o mais bonito preto e vermelho
neste momento só tenho , para mim o melhor capacete do momento  BMW System 7, ainda um Schuberth C3 pro e o HJC
O Scuberth C4 que adquiri na Alemanha estou já á um mês com um caso aberto no PAYPAL , á espera do dinheiro, que deve de estar resolvido até dia 29 deste mês
o BMW que tenho é este e nesta cor, foi o melhor capacete que entrou na minha cabeça até hoje, excelente mesmo....
https://www.simakobdmshop.nl/helmen/helm-system-7-carbon-moto.html
Faz de JET,
« Última modificação: Março 19, 2018, 17:45:33, 17:45 por Clemente Vicente »
Novembro 25, 2018, 02:50:58, 02:50
  • 5394
Grão a Grão, Comemos Feijão!
E sempre com boa disposição!
Novembro 25, 2018, 05:35:25, 05:35
Dois testes para interessados neste capacete:
http://www.moto-journal.fr/news/equipements-et-accessoires/video-test-produit-casque-shoei-neotec-2/
https://www.motomag.com/Casques-modulables-premier-essai-du-Shoei-Neotec-2.html#.W_oBdXd2uUk
o meu Shoei neotec 2 como é o novo modelo de 2019 o vendedor informou-me que só irei receber no final de Janeiro
quero ver se não me lembro
este,
Novembro 25, 2018, 10:34:13, 10:34
  • 18434
Um pouco estranha essa demora toda, tendo em conta que já se encontra à venda em inúmeros websites...
Tem que ver com o grafismo específico nesse capacete que te interessa, Clemente?
Novembro 25, 2018, 11:52:33, 11:52
Sim,
são quatro grafismos novos e novo nome do modelo, SPLICER e mais algumas alterações segundo li,   :pensador: e só começam a receber em meados ou fim de Janeiro
é verdade porque até consta em muitos sites dos comerciantes e tb da minha conversa com eles o prazo de entrega era idêntico
https://www.fc-moto.de/epages/fcm.sf/?ObjectPath=/Shops/10207048/Products/Shoei-Neotec-II-Splicer/SubProducts/Shoei-Neotec-II-Splicer-0019&Currency=EUR&Locale=pt_PT&utm_source=Portalexport&utm_medium=GoogleShopping&utm_campaign=GoogleShopping_PT&utm_term=Shoei%20Neotec%20II%20Splicer%20Capacete&gclid=EAIaIQobChMI7aerq7zv3gIVbjPTCh26NQHAEAQYASABEgLscPD_BwE
« Última modificação: Novembro 25, 2018, 11:55:05, 11:55 por Clemente Vicente »
Novembro 26, 2018, 09:00:34, 09:00
Hemisaro
Mandas vir online ou de uma loja por cá?
Novembro 26, 2018, 09:44:00, 09:44
Cá não se compra nada, nem ferro velho
mandei vir de fora, aliás eu mando vir tudo de fora,neste caso desse grande país que é Italy
ainda na tão badalada sexta feira negra, coprei mais um blusão revit para a coleção e já vão 6 revit , desta vez foi o  modelo SAFARI em azul e branco a excelente preço
Novembro 26, 2018, 10:03:19, 10:03
Fogo... Clemente isso é que são blusões  :smiley:
O Safari já é o 3?
Novembro 26, 2018, 10:13:58, 10:13
O Safari já é o 3?
Não, o modelo Safari é o primeiro, este,
agora Revit já são seis salvo erro , tenho o Tornado, Neptune GTX, o HV , o Airwave 2 e ???
« Última modificação: Novembro 26, 2018, 10:15:32, 10:15 por Clemente Vicente »
Janeiro 20, 2019, 12:15:49, 12:15
  • 18434
As novas cores dos capacetes da Shoei (mod. Neotec II) para 2019...  :nice:
Janeiro 20, 2019, 15:09:45, 15:09
Segundo li já não sei onde, em uma página japonesa, estes novos designs são baseados ou revelam  samurais
Janeiro 20, 2019, 17:07:37, 17:07
  • 18434
Será isto que se encontra nesta imagem, ou seja...a marca dar-lhes-á a designação de "Modern Samurai Style Graphics":
