Marcas de Motociclos
Italjet Caffeina V2 250cc (2019)
Tópico: Italjet Caffeina V2 250cc (2019) (Lida 2047 vezes)
Novembro 20, 2018, 13:42:23, 13:42
Lida 2047 vezes
"The Italian manufacturer Italjet now also enters the motorcycle business with the new Caffeina. The naked bike relies on retro-look and a small V2 engine.
Italjet was previously for scooters - fancy scooters like the new dragster . Now the Italians are also entering the motorcycle business. Door opener should be the new Italjet Caffeina.
The Italjet Caffeina, like many competitors, relies on a vintage garment paired with modern technology. The heart of the Caffeina is an air-cooled four-stroke V2 with 250 cc capacity and five-speed gearbox. As power 17.7PS and 19 Nm torque are called. This should be the dry barely 129 kilograms Caffeina up to 120 km / h fast.
The backbone of the Caffeina forms a steel tube frame. The box rocker with top pull, which is supported by a central strut, is made of steel. Front leads an upside-down fork. The tires of the Caffeina put forward on a 17-inch wire spoke rim, which is equipped with a 110 / 80er Pneu. At the back is a 15-inch rim with a 130/90 tire. Alternatively, a 17-inch bike with a 130/70 tire is also available. The ABS equipped brake system uses Wave discs. Front delayed a 280mm disc, behind a 240 mm disc."
LINK
Novembro 20, 2018, 15:13:33, 15:13
Motociclista: 4 estrelas ❇❇❇❇
Re: Italjet Caffeina V2 250cc (2019)
Gostava de a testar
Novembro 20, 2018, 17:02:19, 17:02
Em 2014 já tinham apresentado um concept... Ou seria a Longjia com lettering da italjet...
Era a Buccaneer 250i, uma Retro Café-Scrambler.
Tem por ali semelhanças...algumas...
Novembro 20, 2018, 21:48:55, 21:48
Marca Motociclo: Moto Guzzi
Modelo Motociclo: V85TT
Localidade: Benavente
Gostei muito do que vi, fico a aguardar o teste do MPANeves.
