Marcas de Motociclos
Kawasaki
Recall: Kawasaki Z900 e Z900RS
Tópico: Recall: Kawasaki Z900 e Z900RS (Lida 2965 vezes)
Dezembro 19, 2018, 13:37:34, 13:37
Lida 2965 vezes
Está a decorrer um recall a nível Mundial dos modelos da Kawasaki Z900 e Z900RS (MY18) em virtude de terem sido detectados problemas potencialmente graves com a cablagem do sistema de travagem na roda traseira.
Segundo avançam algumas publicações, serão cerca de 10.000 unidades a necessitar de intervenção, com substituição da cablagem, pois o sistema de travagem pode falhar em utilização.
A subustituição será, naturalmente, sem encargos para o cliente.
"Brake and ABS could fail
Incorrectly laid cables to the rear wheel can rub against the tire and thus be damaged. Affected are the brake hydraulic line and the cable that leads to the ABS sensor on the rear wheel. If the lines are damaged, braking and / or ABS failure may occur. In addition, the tacho signal that runs on the same sensor can also fail."
https://www.motorradonline.de/motorraeder/rueckruf-2019-kawasaki-z-900.1060630.html
"Z900 ABS and Z900RS models are recalled to the dealer because the rear brake hose and the rear wheel rotation sensor wire may be positioned incorrectly, allowing them to make contact with the rear tire. If the brake hose wears out, the braking pressure can drop out and if the rotating sensor wire is broken, the ABS can no longer function properly and even fall out. In both cases this can lead to a dangerous situation with a possible crash as a result."
https://www.nieuwsmotor.nl/motornieuws/23965-recall-2018-kawasaki-z900-en-z900rs
Kawasaki
