Autor Tópico: MV Agusta Brutale 1000 RR 2020  (Lida 2468 vezes)
Novembro 04, 2019, 13:11:52, 13:11
Lida 2468 vezes
» Model 2020 series declined from the exclusive edition Oro Series 2019
» 4 cylinders in line of 998 cm3
» Maximum power: 208 hp. at 13,000 turns
» Max torque: 116.5 Nm at 11,000 rpm
» Vmax announced: 300 km / h
» Aerodynamic supports
» Old 4 cylinder base completely overhauled
» Arrow Exhaust System Valve, 4-1-4
» New EM2.0 electronic management unit specially dedicated to the 4-cylinder platform
» Ride By wire, 4 modes of conduct
» Inertial unit: TC (8 levels + OFF), anti-wheelie, AR wheel lift control,
» Starting simulator
» Quickshifter
» frame mix: steel and platinum tubes in aluminum = tradition MV + aluminum single-sided
» Öhlins Nix EC fork, electronic hydraulic adjustment, manual preload
» Öhlins TTX shock absorber, electronic hydraulic adjustment, manual preload
» The Öhlins steering damper is also electronically managed
» Same braking as the Oro: Brembo Stylema monobloc radial callipers, 320 mm discs
» ABS Bosch 9 Plus with Race Mode
» LED lights, daytime running lights and cornering lights
» Forged aluminum wheels (carbon fiber rims on Serie Oro)
» Steel screwdriver (titanium on Oro Series)
» 186 kg dry
» 5 'TFT display, connected
» Speed ​​regulator
LINK   LINK   LINK
« Última modificação: Novembro 08, 2019, 10:38:13, 10:38 por Sapiens21 »
Novembro 04, 2019, 13:14:11, 13:14
Vejam bem o design da traseira desta moto, especialmente o cuidado aplicado no look e disposição dos escapes desta Brutale 1000RR (última foto).  :feliz:
Que coisa mais....mais...  :tirarchapeu:
Novembro 08, 2019, 11:51:37, 11:51
Nem tinha reparado que já por aqui andava... estava escondida ou então de tão bruta que fugiu logo...  :lolol:
É mesmo BRUTALE e em tudo:
- especificações e características
- design geral e alguns pormenores estilisticos
- preço (altamente brutale)
- 186kg a seco face aos 208cv
Será a justa concorrente "a dois" com a novíssima Ducati Streetfighter V4 e o resto da concorrência está uns "tirinhos" abaixo...
E aparentemente há uma versão ainda mais exclusiva em que a potência sobe para 212cv (julgo com um escape da SC project, a serie oro.)
Sobre os vários pormenores...
- as asas aerodinâmicas normalmente agora vistas no MotoGP
- o banco dividido em 3 partes (conforto/ergonomia ? )
- acho que falharam num único pormenor, dentro do farol da frente, há uma peça plástica encarnada que poderia ganhar a cor amarela no respectivo modelo preto/cinza/amarelo
Mas no geral... que obra prima!!!
Novembro 20, 2019, 15:50:38, 15:50
Vídeo oficial de apresentação do modelo (Eicma 2019):
